Parrot Asteroid
Old Oct 15, 2012 | 10:07 PM
juntsky's Avatar
Default Parrot Asteroid
I'm highly considering this headunit but when I searched found nothing of real use. Has anyone used this HU before? Is it a 4ohm unit? does it fit in our cars?
Old Oct 16, 2012 | 07:28 AM
Reckon's Avatar
http://www.crutchfield.com/p_333ASTR...crv=8739865585
Won't fit without some modifications. Requires you to cut the european harness and replace with the required harness. Also doesn't play CDs, just FYI.
Old Oct 16, 2012 | 08:48 AM
juntsky's Avatar
Don't care much about CDs since it goes on my phone anyway. I don't need to modify the dash in any way to make it fit do I? Just the HU?
Old Oct 16, 2012 | 01:11 PM
Boost-Me's Avatar
All Parrot equipment I have installed works pretty flawlessly. The installation should be the same as installing any aftermarket radio, just keep in mind you will need the Honda wire harness to install the head unit with out cutting any factory wiring.
Old Oct 16, 2012 | 01:12 PM
Boost-Me's Avatar
Looks like it is just a single din unit so the only issue will be if the volume knob sticks out far enough to hit the door. It doesn't look like it will, but I can't say 100% that it won't having not installed on before in a s2000.
Old Oct 17, 2012 | 07:18 AM
aphex4000's Avatar
It appears to fit without any problems in this video.
isthisusernameavailable
Sep 24, 2018 04:21 PM
kerm1t
Aug 7, 2013 09:07 PM
hook3549
Dec 21, 2010 12:40 PM
hellspare
Oct 21, 2008 12:15 PM
alex.stanley
Nov 5, 2005 02:10 PM
