Passenger side window will not open!
Old Aug 24, 2012 | 06:13 PM
JohnnieChoi's Avatar
Default Passenger side window will not open!
The car is a 2002 s2000! silver! Love this car! But there is a slight problem.
The window will not go back up from the drivers side control, nor the passenger side control, but I can hear a switch clicking when push down on the "roof" switch. I can assume that power is going to the window, but there is no power to the relay switch.
What should be the next step in trying to take care of this problem??
Old Aug 24, 2012 | 07:21 PM
Jonzyy's Avatar
Check the drivers side for the passenger window "lock," make sure it is not on. If that doesnt solve it then take one the door panel and look for the problem, either regulator or track issue.
Old Aug 25, 2012 | 04:57 AM
It was the window lock!! I'm so newb..
Old Aug 25, 2012 | 10:16 AM
acharlie13's Avatar
Hello ,
I had the same problem with my passenger window. It was stuck halfway. I could also hear the actuator working. I had to do this alone, so I wedged a piece a paper in the control button in the passenger door so it would be rolling the window up, The i grabbed the window and jerked it up , took 3 tries and finally released and rolled up. Been working fine ever since I did that. Not saying this will work every time but, worth a try. Good Luck
Awesome , just seen your additional post. Glad to see it's working. Wasn't that easy in my case.
Old Sep 3, 2012 | 01:46 PM
unclefester's Avatar
Good to see folk falling for this on your side of the pond We usually drag it out for longer
plizzat
Aug 10, 2015 03:49 PM
Oh4sh0
Jun 13, 2015 06:24 AM
jammer2209
Mar 15, 2011 12:49 AM
blippy
Mar 21, 2010 11:44 AM
Currahee474
Nov 5, 2006 01:22 PM
