Passenger Window goes down, but not up from drivers switch
Morning everyone,
I have a window problem. And it's not the window-disable-button accidently pressed down (sorry to disappoint!). The situation is:
From driver's side switch: Drivers window goes up and down fine (although slight judder on the way down)
From driver's side switch: Passenger window goes down (again, with a slight judder), but doesn't come up when I hold it. It sometimes works, sometimes comes up in stages, sometimes doesn't budge at all.
From passenger's side switch: Passenger window goes up and down without a problem.
I've sprayed silicon grease down the seals to loosen the mechanism up, and that didn't really solve anything.
The solutions I've read about are: Fuse / control unit / window regulator / bad switch.
What annoys me is that the fault isn't always there. It sounds like a failing part - either window mech or switch I guess. Is there anyone around Oxfordshire that I could meet up and swap a working switch with? Any ideas/previous experience would be appreciated.
Cheers
Cheers
I'm not an expert, but if the passenger side switch drives the window going up/down correctly, doesn't that immediately point to a problem in the drivers side?
In my simple brain, if the passenger side switch works fine, then it eliminates the mechanism to drive the window itself - motor/seals etc.
It could be a fuse, but if the fuse regulates both switches, then again, I'd eliminate that as the passenger side works fine.
I'd look more closely at the driver side as that seems to be the source of the issue.
Dirty contacts/loose wiring perhaps?
As maby says, it'll be a connection issue relating to the drivers switch wiring, on something unique to that circuit not after it's combined with the passenger switch bit.
Hope that makes sense.
This is deffo an electrical problem. Download the service manual it's in the FAQ's as a .pdf page 22.121. It sounds like the drivers overide for the passenger window going intermittant. The judder on the drivers window is loose screws on the rail that holds the window, had the same on my CRX, and can be fixed with a screwdriver.
"Wouldn't that make the passenger switch intermittent aswell?" I don't think so Dan looking at the (weird Honda) diagram.
Thanks Rich,
I'm probably being stupid, but the owners manual I was looking at doesn't go up to 22.121. I'm trying to download a pdf version as I was looking at this:
http://issuu.com/onderhoud/docs/hond...rvice_manual02
The loose screws on the rails. Are these accessible with just removing the door card, or will I need to remove the metal skin as well?
Cheers everyone. I went to have a good look on Sunday, but typically it began working fine. It was playing up yesterday, so pulled off the doorcard to have a look. No bad connections, dirt or broken pins as far as I could see.
Does anyone live in the Oxford area so I could meet up and swap a doorcard over to try a different switch. It's 3 screws and a 5 minute job for those that haven't tried it, and it'd be a great help.
Cheers
Jamie
Cheers
Jamie
Thanks Rich,
http://hondatech.info/search/s2000/
I've only done the window rail screws on a CRX, on that you had to line the screws up with holes in the panel by moving it up/down, not a difficult job (on the CRX) so it ought to be card only.
