Pioneer P8MP 40W -> 60W
Old Oct 18, 2005 | 06:30 AM
S2000_TYPE_S's Avatar
Default Pioneer P8MP 40W -> 60W
any way to do this without opening up the panels and taking the HU out?
whats the easiest way to do this?
Old Oct 18, 2005 | 08:38 AM
SheDrivesIt's Avatar
Easiest way to do what? Threat title says "40W -> 60W". What do you mean?
Old Oct 18, 2005 | 08:48 AM
maybe i wasnt being too clear..
The default setting on the P8MP head unit is 40W per channel. There is an option to change the output to the max of 60W per channel by activating the switch on the bottom of the HU.
I was wondering whether there was a way to do this without taking out the HU again.
Installation was done professionally and was set to 40W because I had the stock speakers..
Just bought a set of Kicker components and would like to increase the output to 60W.
Old Oct 18, 2005 | 08:55 AM
jwa4378's Avatar
First of all....there is no way you are going to be getting all 60W. You will probably be getting 22-25WRMS. Those Kickers are probably rated a 60WRMS, not 60W max. Ignore the MAX wattage numbers for both, as that is a useless number and is only achieved under lab conditions. Look at the WRMS rating. That is the only way to get a "true" wattage reading.
As far as pulling the HU...that takes all of like 2 minutes. Just open the radio door, pull up and out and the whole thing (vents and all) should just pop right out. Then its just 4 phillips screws, then pull it straight out. Takes less than 90 seconds for me to pull mine out, if I have a power drill handy for the screws.
John
dirtykoala
Jan 31, 2011 09:14 AM
bikemechanic
Feb 19, 2008 05:28 AM
S2Harv
Nov 9, 2007 12:03 PM
QSilver7
Dec 19, 2003 10:33 AM
David1
Apr 5, 2003 07:50 PM
