"Power and Ground wires"
Old Aug 27, 2006 | 08:06 PM
s2kheat's Avatar
Default "Power and Ground wires"
I'm looking at amps and have a question on power gauge and ground requirements.
If an amp requires an 8 gauge wire, is this what I need to use or can I go with a bigger 4 gauge?
Sorry if this is a stupid question.
Old Aug 27, 2006 | 08:21 PM
globallyoff's Avatar
If it requires an 8 ga., you can just use that or anything bigger such as a 4.
Old Aug 27, 2006 | 08:34 PM
s2kheat's Avatar
Thank you!
I appreciate the help.
Old Aug 28, 2006 | 09:44 AM
NFRs2000NYC's Avatar
Its not that simple....
First of all....WHY!? If it requires 8AWG, why run 4? Its bigger, weighs more, harder to run, etc etc....why bother?
Secondly, you will have to trim a lot of wire (half of it) to get it to fit into the amp terminal. 4AWG is very thick, so be prepared to deal with it. If your amp requires 8, use 8.
Old Aug 28, 2006 | 10:16 AM
Ubetit's Avatar
I'll go even further and say that most amps don't even need 16. looks cool though.
Old Aug 28, 2006 | 10:38 AM
s2kheat's Avatar
I guess I'll be returning the kit if I need to trim the wires.
Thanks for the info though.
Old Aug 28, 2006 | 10:40 AM
MugenRioS2k's Avatar
Run the largest main power wire you can afford at the time of your first amp install and use a distribution block if that wire needs to be sized down for your amps.
This way you will never need to run more power wires from your battery if you decide to up grade to a bigger amp later on.
Also make sure your main ground wire is at least one size bigger then your power wire (good rule of thumb in the industry all though installers rarely ever follow it).
Also use a distribution block for your grounds if using multiple amps to reduce the chance of ground loops.
Don
Kengthao91
Jun 29, 2012 10:31 AM
VinDieselJetta
Feb 3, 2011 03:02 PM
preppyS2000
Jul 30, 2007 06:35 AM
vampire
Jan 4, 2005 02:37 PM
r_duff
Sep 16, 2004 02:05 PM
