Problem with alpine 9827
Old Mar 23, 2005 | 06:17 AM
Spec_Ops2087's Avatar
Default Problem with alpine 9827
I've currently had my alpine 9827 for a little over a year now and it has been great. However, recently it has been having a very annoying problem. I always use MP3 cd's with the stereo and most of my cd's have about 150 songs+. The problem with the stereo is that after about track 120 or so all of the tracks skip severly or just don't play at all so I cannot listen to tracks 120-the end of the CD. But when I skip to the beginning of the CD all the tracks until about 120 work. I use Nero to burn the MP3 cd's.
I think I am out of warrenty so is there anything I can do or am I screwed.
And yes I have tried making new cd's and even a brand new one does the same problem.
Regards,
Jonathan
Old Mar 23, 2005 | 06:23 AM
Darien1629's Avatar
are you over burning on the cd? cause that could be the problem
Old Mar 23, 2005 | 06:30 AM
nope I only use about 400Mb of space on a 650Mb disc
Old Mar 23, 2005 | 06:39 AM
Darien1629's Avatar
wer eyou able to play past track 120 before? or maybe try and put them in diffrent folders.
Old Mar 23, 2005 | 06:47 AM
my mp3's arn't in folders mainly because I just do random play. However I can't do random play anymore becuase it will go to a 120+ once every 2 songs so that gets flat out annoying. I am forced to listen to the songs in order now because of it.
The player used to play songs 120+ but recently it has decided not to, to the point where it is annoying and I need to fix it somehow
Old Mar 23, 2005 | 06:54 AM
Darien1629's Avatar
not sure then. sorry i couldnt help more
Old Mar 23, 2005 | 03:50 PM
DiamondDave2005's Avatar
Did you try cleaning the laser? You can buy a cleaning CD with little bristles that sweep the dust off the lens.
It might be a cheap fix.
Old Mar 23, 2005 | 04:54 PM
I actually figured out what it was -- I installed the remote switch to make the volume work on the left side of the steering wheel and I pulled power from the headunit. It must have erased my settings -- it was set to CD-UA (I believe) -- switched it to CD/MP3 and it works great again. Thanks for your time
4urmrs
May 30, 2012 12:09 AM
philipf22
Mar 27, 2008 07:51 PM
emerlin
Feb 2, 2008 12:03 PM
Andy Kirk
Oct 9, 2004 11:00 PM
peterpan
Feb 8, 2002 10:09 AM
