Problem a/c always on
Old Apr 6, 2017 | 05:23 PM
Stevens2000ap1's Avatar
Default Problem a/c always on
Hi I have a weird problem with my A/C. my car is a 2003 ap1 with custom turbo kit hx35 with a full build motor and running Doctronic pro ecu
The problem started last year randomly.
When i Start the car with interior fan at off the ac clutch isnt engaged (which is normal)
If i set any fan speed on without activating a\c the ac clutch isnt enganged (which is normal)
If i set Ac On, it engage but even if i turn it off after a while, the clutch will stay engaged and fans will run until i shut off the car.... (which i think isnt normal)
I can clearly see when the ecu receive the signal for ac clutch in my log and will stay on all the time until I turn off the car otherwize will run even with heat off
Any idea?? sorry for my bad english i'm a french native and I have a really hard time to explain
Old Apr 10, 2017 | 01:35 AM
windhund116's Avatar
You have the options set to blowing up onto windshield? You turn fan on, I think the A/C automatically flips on? Kind of a "defrost" or "de-fog" mode.
Old Apr 10, 2017 | 03:32 AM
Chuck S's Avatar
The AC is automatically activated when air is directed to the windshield vents. This is user-settable with a series of switch presses. Defaults back if the battery is disconnected.
How to disable AC when defrost is selected.
-- Chuck
Old Jun 10, 2017 | 08:02 PM
Halfassjack's Avatar
Problem with control head/unit. Saw one do exactly same thing.
Old Jun 12, 2017 | 06:53 PM
Does he need to replace the unit? Or just fix (reprogram?) it?
Thanks!
Old Jun 12, 2017 | 07:08 PM
Verify why it stays on. Data capable scanner not code reader. Identify what is keeping it on and check inputs and outputs. The one I dealt with had faulty chip in module. Rare but does happen .....usually with help from shorting out from external i​​​ssue. Used control units are cheap.
Old Jun 13, 2017 | 06:04 AM
Thanks! Be nice if the OP would respond to the suggestions.
Devinb
Feb 28, 2013 04:07 PM
sbrodacz
Jul 12, 2008 01:44 PM
justcliff
Sep 27, 2007 11:14 PM
jumper1564
Dec 22, 2003 06:51 AM
