Clutch problem
Old Sep 27, 2007 | 05:39 PM
justcliff's Avatar
Default Clutch problem
My wife was driving my car to get the top replaced yesterday and said that first gear went out, she said she had to start off in 2nd, and that 3rd and 4th were a bit of a problem, but it ran fine, reverse was also a problem, but it always is for her. She complained earlier that it felt as if she had to push the clutch in 3/4 of the way before she felt any tension or grab.
From what I've gathered it seems as if there is air in the system and it needs to be bled, would it be safe to add some fluid to the resivior and pump the clutch to get it home, or should i take tools and bleed the system when i pick it up, any advice would be greatly appreciated.
Old Sep 27, 2007 | 06:19 PM
Stratocaster's Avatar
If I remember correctly, 1-2 and R are all part of the same set of gears/syncros. It sounds to be that you don't have a clutch problem, but a transmission problem. Sounds to me that you need to have the 1-2/r syncros replaced. They are sold as a set with the gears.
It is cheaper to find a good used transmission than to repair your existing transmission.
Old Sep 27, 2007 | 09:35 PM
GuardsRed's Avatar
does it grind at all or no?
Old Sep 27, 2007 | 11:06 PM
BrandonS2K's Avatar
it needs to be bled and i would put some fluid in it if its low and drive it home it actually seems to get better with the addition of the new fluid. the fluid is dirty and needs to be changed
Old Sep 27, 2007 | 11:14 PM
s2k dre's Avatar
let me know i live in orlando! i could look at ur car.
Projectfocus
Jan 8, 2017 09:08 PM
tabbyfl55
South Florida
Sep 10, 2015 05:14 AM
Lateralusticus
May 28, 2013 01:20 AM
s2000afterlife
Feb 8, 2013 07:09 PM
MaskedAP1
Sep 5, 2007 06:21 AM
