Prologger
Old Jul 12, 2006 | 10:27 PM
LS1inOC's Avatar
Default Prologger
Advanced Injection Technologies, Inc.(AIT) would like to introduce the prologger, a wide band 02 data logger with advanced multifunctional engine controls consisting of real-time monitoring of Air/Fuel ratio, rpm, elapsed time, and boost/vacuum on a super bright LED display. Prologger can also be used to control boost, nitrous, fuel remapping, and HONDA VTEC all this with no laptop!!!
Features:
1.Wideband Air/Fuel controller with programmable outputs compatible with most stock and aftermarket EFI computers. Will run wideband closed loop with most aftermarket systems and narrowband switching on factory ECM's for economy and emissions.
2.Built in closed-loop boost control with 3 operating configurations
- 5 point RPM vs. Boost curve.
- Max set point.
- Drag race, low set point to high set point with programmable time to ramp between.
3. Digital playback gauges for air/fuel ratio, tachometer, elapsed time, and boost/vacuum.
4.Totally stand alone logging and playback of air/fuel ratio, rpm, elapsed time, and boost in 1/10 second increments. No laptop required!!!
5. Safest nitrous oxide system around that allows you to run 1, 2, 3 stages of nitrous oxide control with Never lean nitrous shut down.
6.fuel remapping, 24 point rpm vs. manifold air pressure control allows user to change stock ECU fueling to plus or minus 50%
7.Launch control allows data logger to be sarted by transbrake, linelock, ect.
8.Honda VTEC control
9.2 configurable rpm, elapsed time, air/fuel ratio, and boost activated window switched outputs for control of fuel enrichment, water injection, turbo spool-up with nitrous, shift lights, lean lights, rev limiting, ignition retard, iignition cut due to lean conditions.....or other innovative control solutions.
prologger is the perfect tool for amateur though pro. It allows everyone to tune his or her vehicle to peak performance.
for additional info or to place an order contact me at jdm379@hotmail.com or www.prologger.com
Chris@NLM
Jul 2, 2016 01:11 AM
need_boost
Oct 9, 2014 03:56 PM
s2kseven
Oct 13, 2013 09:10 AM
stantaur
Apr 22, 2013 11:00 AM
esoteric
Nov 7, 2006 08:05 AM
