Need help with my system
Old Jun 6, 2006 | 08:06 PM
hondax2000's Avatar
Default Need help with my system
Whats up guys I just installed my system and it was working fine but as I was driving to work today I hit a little bump and the sub just stopped. So when I got there I looked at it and the red light would be on then it would flick off for a second then come back on. I thought the amp may have blown so I tried another Kicker amp that I have. That one did the same thing the sub would work for a second on this one then the protection light would come on them go back off after a couple seconds. Have any Ideas?
Old Jun 6, 2006 | 08:29 PM
boyguan's Avatar
maybe the sub is blown and causing the amp to go into protect.
Old Jun 6, 2006 | 08:43 PM
hondax2000's Avatar
well i hope thats not the case but I will have to borrow a friends sub and try it out.
Old Jun 6, 2006 | 09:23 PM
spoon us's Avatar
maybe your remote,the blue wire
Old Jun 7, 2006 | 07:42 AM
DFWs2k's Avatar
or the ground may not be good
Old Jun 8, 2006 | 10:35 PM
hondax2000's Avatar
thanks for the suggestions I am going to work on it tomorrow nite. any others?
Old Jun 8, 2006 | 11:35 PM
Will's Avatar
If you've swapped the amp already, then troubleshoot external sources of the problem. They could only be: power, ground, remote, or your sub.
Or, you could be totally fuxored, and the deck's internal remote turn on is broken. That would suck.
Old Jun 21, 2006 | 12:05 PM
hondax2000's Avatar
Ok gusy so i fixed the problem by grounding it better but now it startind doing it again everytime i went over a bump the sub turned off then back on and then it just went toatly out?
Old Jun 21, 2006 | 03:37 PM
jwa4378's Avatar
Did the ground come loose again? Possibly a faulty amp (had a bad Audiobahn a few weeks back on an install of mine)?
John
Old Jul 12, 2006 | 10:42 PM
hondax2000's Avatar
I think the amp is fine because I tried a different amp and that one was in protection mode too. I am going to try to re-wire everything tomorrow.
johnqt3
May 5, 2008 11:24 AM
DFWs2k
Feb 6, 2008 10:33 AM
Doug1627
Dec 13, 2007 05:19 AM
Tom0
Mar 6, 2006 07:01 PM
SilverstoneS2k_FL
Feb 21, 2005 04:36 PM
