Question on Auto locking behavior
Old Jun 1, 2017 | 05:24 PM
watchdogd's Avatar
Default Question on Auto locking behavior
I have started to experience strange behavior with the driver side door. The manual indicates that one should not be able to lock the door if either of the doors are open.
Recently however, if my driver side is open the car will still auto lock. If its just the passenger side that is open everything works as expected. I replaced the driver side actuator thinking that was the problem but the problem still persists.
What is strange it will only auto lock if I originally unlocked it with the remote. If I manually unlock the driver side, it will remain unlocked as expected.
Is there some sensor or fuse I should look to replace that might be causing this strange behavior ? I reprogrammed it again and that did nothing as well.
Thanks,
Old Jun 2, 2017 | 01:35 PM
watchdogd's Avatar
Turns out it was the assembly switch part number: 35400-S0X-A01
The connection as loose. So hopefully if anyone experiences the same symptoms they can trouble shoot that part as well
Genma
Oct 19, 2011 12:50 PM
Genma
Oct 16, 2011 02:44 PM
Alastair
Sep 10, 2010 02:07 PM
elude
Jun 30, 2005 04:15 PM
Y2TuCkY
Oct 12, 2004 07:35 PM
