Problem with keyless entry!
Old Oct 12, 2004 | 07:08 PM
Y2TuCkY's Avatar
Default Problem with keyless entry!
My stock remote is going retarded on me. It would only unlock the passenger door and not the driver. Trunks works fine and panic button works fine. Driver side wont response to anything. If i lock the door manually, then the passenger side won't unlock with the remote either. I know the problem is from the driver side. I check the keyless fuse and it was fine! What seems to be the matter ???!
Old Oct 12, 2004 | 07:10 PM
chaseabryant's Avatar
Possible motor burnout?
Old Oct 12, 2004 | 07:13 PM
Y2TuCkY's Avatar
hope not!!! How can u tell if it's burn?
Old Oct 12, 2004 | 07:23 PM
The first thing I would suggest you do, is listen up close while pushing the unlock button, and seeing if the lock makes any noise while pressing the unlock button..
If it does not make any noise, I would suggest taking it into the dealer... I'm not an expert on this subject, but Little motors in the doors of vehicles tend to have a little more wear and tear than others. You might have jostled some wires if you have shut the door to hard as well. I would just suggest though, like I said above, take it to the dealer, and don't fiddle with it yourself unless you have the knowhow.
-Chase
Old Oct 12, 2004 | 07:27 PM
Y2TuCkY's Avatar
Thanks bro. It does make noises near the fuse box but no where near the door. If i get an after market alarm, will my problem be solve? Or they just use the stock motor also? WHY ME!
Old Oct 12, 2004 | 07:35 PM
I don't think that they replace the motors with an aftermarket alarm, I'm quite sure that they stick with the stock motors. I'm sorry to hear about the trouble, but it is a fairly easy fix. Probably an hour max at the shop.
-Chase
Genma
Oct 19, 2011 12:50 PM
Genma
Oct 16, 2011 02:44 PM
hondax2000
Oct 13, 2011 12:50 PM
Alastair
Sep 10, 2010 02:07 PM
oyitzpreston
Mar 31, 2008 05:41 PM
