Questions on speakers and a deck.
I just installed an Alpine CDA 9883 CD player in my car and I was also planning to install a set of Infinity Kappa Perfect components. Would they sound decent if i run them off the deck?
The deck is rated at 18 watts rms, and the speakers are rated at 100 watts rms. My friend keep saying the deck is too underpowered for the speakers.
Another question and its sorta crazy but since the S2K only has two front speakers, can i run both the front left and rear left speaker outputs to my left component for a total of 36 watts rms (18+18) and same for the right?
don't bridge off a headunit , never a good idea... it will provide enough power for the mean time but you'll get distortion at a lower volume than you would when you have an amp , which is key when you've got a convertable.
LOL the power output will remain the same if you try bridging a HU. Reason being, HU amps are actually 8ch amps that are bridged down to 4ch, so if you try bridging it, it just bypasses the internal bridging.
