Questions on speakers and a deck.
Old Aug 22, 2007 | 11:16 PM
slipper's Avatar
Default Questions on speakers and a deck.
I just installed an Alpine CDA 9883 CD player in my car and I was also planning to install a set of Infinity Kappa Perfect components. Would they sound decent if i run them off the deck?
The deck is rated at 18 watts rms, and the speakers are rated at 100 watts rms. My friend keep saying the deck is too underpowered for the speakers.
Another question and its sorta crazy but since the S2K only has two front speakers, can i run both the front left and rear left speaker outputs to my left component for a total of 36 watts rms (18+18) and same for the right?
Old Aug 23, 2007 | 04:53 AM
imdarkrider's Avatar
don't bridge off a headunit , never a good idea... it will provide enough power for the mean time but you'll get distortion at a lower volume than you would when you have an amp , which is key when you've got a convertable.
Old Aug 23, 2007 | 06:16 AM
other_vortechs2k's Avatar
You definitely do not want to do this. Having two outputs attempting to drive the same load leads to burnt transistors. Also, even if you assume that the left front and rear outputs are sending the same signals (which they don't always do), the output would still be 18W rms.
Old Aug 23, 2007 | 08:46 AM
slipper's Avatar
OK so scratch the idea for bridging the fornt and rear speaker outputs.
But to the first question. Is the factory deck enough to power the Kappa Perfect components?
Old Aug 23, 2007 | 02:30 PM
slipper's Avatar
nevermind. I decided to get an Alpine PDX 4.100
Old Aug 23, 2007 | 08:27 PM
GTS Jeff's Avatar
LOL the power output will remain the same if you try bridging a HU. Reason being, HU amps are actually 8ch amps that are bridged down to 4ch, so if you try bridging it, it just bypasses the internal bridging.
Old Aug 23, 2007 | 08:45 PM
slipper's Avatar
Just finished installing the CDA-9883 and PDX 4.100. 2 channels are running to the two speakers and the other two channels will be bridged for the subwoofer.
Old Aug 23, 2007 | 11:09 PM
DDuds2k's Avatar
hows the sound?
Old Aug 24, 2007 | 01:17 AM
slipper's Avatar
Im still running the stock speakers and no sub... so far so good. Ran out of time installing the amp and deck today. Surprisingly the amp fits fine under the passenger seat.
Irichardson
Jun 21, 2013 04:49 PM
watchdogd
Jan 6, 2009 05:27 PM
VTEC Racer
Dec 27, 2008 08:48 PM
Mikes256
Jul 16, 2006 04:23 PM
Dracoro
Jan 30, 2003 06:23 AM
