Quick question before I order the Modifry DCI
Old Jul 21, 2005 | 02:34 PM
Superfly05's Avatar
Thumbs up Quick question before I order the Modifry DCI
I am getting the sony wired DCI for my pioneer HU. Since the pioneer is compatable with it. I was just confused if I need to order the S2000 harness adapter with it as well? Dumb question, but not sure. I am leaning towards the no side.
Thanks,
Jon
Old Jul 21, 2005 | 03:08 PM
jwa4378's Avatar
PM "Modifry" and he could tell you.
john
Old Jul 21, 2005 | 03:33 PM
PJK3's Avatar
his PM's are disabled. you can email modifry at Bob@modifry.com
Old Jul 21, 2005 | 04:56 PM
r_duff's Avatar
im pretty sure u dont. I dont know how much different the 'wired' dci is comparted to the regular IR... but the IR DCI IS the harness.
Old Jul 21, 2005 | 05:40 PM
Superfly05's Avatar
Huh! That makes sense. I might have to email "modifry" on this one. Or maybe just say screw it and order it without it. Damn't.
Old Jul 21, 2005 | 07:27 PM
jwa4378's Avatar
That sucks. I guess it makes sense.......he would be getting a TON of PM's regarding his stuff. From what I know of him, he is a good guy, so email him and he should reply within a day or so.
John
Old Jul 21, 2005 | 08:05 PM
PJK3's Avatar
he disabled his PM's because he was getting multiple PM's here and emails as well, often from the same people, but usually w/o any association between the 2 names (screen and email/real). so, there were a number of problems associated with some that confusion.
i re-read your question...
IF you are buying a new HU. and IF you are buying a DCI. you will need BOTH the S2000 harness AND the DCI to get full install functionality. the S2000 harness is what allows you to plug into the OEM wiring. the DCI just splices in and operates the dash controls, it does nothing else to provide power, ground, speaker leads, etc for the new HU.
i hope this helps.
Old Jul 22, 2005 | 08:55 AM
Superfly05's Avatar
[QUOTE=PJK3,Jul 21 2005, 08:05 PM]he disabled his PM's because he was getting multiple PM's here and emails as well, often from the same people, but usually w/o any association between the 2 names (screen and email/real).
Old Jul 22, 2005 | 12:37 PM
zboy's Avatar
I screwed up and boughta Metra harness... i didnt realize I needed his, or to splice factory wiring (blech). Oh well 15 bucks down the tubes..
Old Jul 23, 2005 | 06:42 AM
PJK3's Avatar
a Metra will work, but you may have to splice into the factory stuff to get the DCI's functionality.
i'd buy some wire taps like these ( http://www.partsexpress.com/pe/showdetl.cf...tnumber=082-140 ) from an Autozone or Radio Shack... and just use that to splice into the OEM wiring. that way, you're not actually cutting the factory harness.
i've used these in a few locations and have had moderate to very good success with them. the biggest thing is to make sure you buy wire taps of the proper gauge... don't get them too big or it won't tap into the factory wiring. the 18-22 should work fine.
Spaceentity
Nov 26, 2016 10:53 AM
SSM_S2k
May 24, 2010 04:47 AM
SupeR_DavE
Feb 20, 2010 02:00 PM
Dog Biscuit
Jul 13, 2009 02:12 PM
s2jeezy
Jan 16, 2009 05:03 PM
