Quick questions.. Electonics expertise needed!!!
Old Feb 10, 2003 | 08:22 PM
Gioire's Avatar
Default Quick questions.. Electonics expertise needed!!!
Has any done the following??
1: Put an auto up on the drivers side window??
2: Put an auto up/down on the passenger window??
3: Found a way to rig the top so you don't have to hold the button?? Up or down?
How to's would be great?? I suck at electronics!!
Thanks in advance!!!
Old Feb 11, 2003 | 04:05 AM
HARDtoTOP's Avatar
I jsut bought a kit from a member that will do that. I am goin to nstall it next week. I will let you know if it works but I have heard nothing but good stories so far from other users.
Old Feb 11, 2003 | 04:59 AM
Bass's Avatar
I've intsalled the auto-up / down on my windows and except for BIG mistake i made (crossed wires) they work like a champ..
i too have to install the top switch but from the instructions it looks pretty easy.. Jeff maybe we can do ours at the same time
btw Gioire here's the link
https://www.s2ki.com/forums/showthread.php?...to%20userid7099
Old Feb 11, 2003 | 05:21 AM
MacGyver's Avatar
I would have to look at the diagram again, but there's potential to use a third module attached to the top switch to allow top auto up/down.
Old Feb 11, 2003 | 06:02 AM
Bass's Avatar
yes Macgyver
you are correct.. you need a separate relay for each window and the top... but if you recall i was running so late that day and i was so aggravated cause i messed up Gesine's window that i didn't even attempt to add it to the top....
Old Feb 11, 2003 | 10:12 AM
TepEvan's Avatar
Can't hold your finger on the button for 6 seconds for the top to go down... I can't believe no one invented an automatic for your s2ks yet
Old Feb 11, 2003 | 10:44 AM
HARDtoTOP's Avatar
Steve, I am going to install mine next week while I am doing my alarm, because I will already have the center console removed to put the proximity sensor in. Do you have any tips or pointers I may want to keep in mind? thanks
Jeff
Old Feb 11, 2003 | 11:03 AM
Bass's Avatar
Jeff the biggest tip i can offer you is not to let me do the work
Glenn and scott did my driver's side in ten minutes while I destroyed my convertable top relay ($150.00) cause I crossed some wires and burnt out the relay
Good luck Jeff
Tepevan ~ It
Old Feb 11, 2003 | 11:08 AM
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by sireousrex
[B]Steve, I am going to install mine next week while I am doing my alarm, because I will already have the center console removed to put the proximity sensor in. Do you have any tips or pointers I may want to keep in mind? thanks
Sin_Chase
Apr 22, 2011 01:32 AM
fujimi
May 1, 2010 04:35 PM
PHILfromNOTTM
Dec 10, 2006 12:12 PM
ade73
Jun 23, 2005 02:49 AM
Karl2k
Apr 18, 2004 07:36 AM
