quick release amp wiring
Old Feb 12, 2007 | 09:35 AM
abv's Avatar
abv
Default quick release amp wiring
Ok
question for all the smart people...
so i have my amp mounted above the tool rack in a pressure fit box...
i want to be able to quick disconnect the wiring to the amp so i can
a: get at the tool kit easier..
b: pull it out for track days..
the amp is for the sub only..
wires: 4 gauge power and ground
pos neg speaker wire
and the little remote wire...
ideally i would like to have an all in one automotive style clip to do this..so i can mount the clip on the box and simply plug it in..
if anyone has a solution that would be great...
Old Feb 12, 2007 | 10:45 AM
PTHermes's Avatar
http://www.partsexpress.com/pe/showdetl.cf...tnumber=263-120
2 of these work great for the power and ground. You can use just about anything for the remote turn on, and as long as you leave the RCA's accessable you shouldn't have a problem.
Old Feb 12, 2007 | 05:41 PM
abv's Avatar
abv
PTHermes thanks for the tip that will work perfectly..
Old Feb 12, 2007 | 09:13 PM
Dcon67's Avatar
That looks just like half of the Stinger SQD4.....
http://stingerelectronics.com/prodDetail.asp?strID=339
Old Feb 14, 2007 | 02:06 AM
Looneybomber's Avatar
The power equipment we have at work (Crown) uses those 1/0ga connectors. They're very durable, but also hard to pull apart. Luckily the 4ga connectors require 1/6 the pulling power required to yank them apart.
wOlLeyLaBeL
Jun 2, 2008 08:15 AM
gtg749m
Dec 9, 2007 03:48 PM
netanderthal
Oct 22, 2007 01:57 PM
cshamash
Mar 5, 2006 05:30 AM
djkojione
Nov 5, 2002 12:37 PM
