Radar Dertector Positioning
Old Apr 2, 2007 | 06:13 PM
Boofster's Avatar
Mine:
Suction cups suck
Can barely tell it's there top up or down.
Old Apr 2, 2007 | 06:21 PM
FearlessFife's Avatar
Originally Posted by Rad Ray,Apr 2 2007, 06:35 PM
Where do you place your radar detector to get optimal detection and accessibility to the power oulet? I've seen the mounted all around the cabin and even hung from the convertible top frame.
Stuck to the glass on the left of the rear view mirror, hard-wired to the overhead interior lighting. I love mine set up that way.
Old Apr 2, 2007 | 06:43 PM
itsmylittlebrothersbike's Avatar
Hard wiring is surprisingly easy. Even if your not mechanically inclined, it only takes an hour. There is an excellent how-to in the electronics forum.
Old Apr 2, 2007 | 07:21 PM
Dcon67's Avatar
My V1 is suctioned to the right of the mirror (Passenger side), and hardwired. I like it better on that side so it's as much out my line of sight as possible. I can't wait for Ricks V1 trim piece, as soon as it's available that's where my V1 will reside.
Old Apr 2, 2007 | 07:24 PM
thejohnremus's Avatar
Originally Posted by AlX Boi,Apr 2 2007, 05:18 PM
Wasn't there a mount before where they put the V1 in the secret compartment then cut a hole and filled it with glass? They then use the mini V1 and attached it into the mirror. That setup obstructs the rear as well, but was considered the best setup.
Yeah, i know which one you're talking about
one sec, I'll find it
https://www.s2ki.com/forums/index.php?showt...79&hl=valentine
here it is!
there's this one by Rick too
http://forums.s2ki.com/forums/index.php?showtopic=67349
Old Apr 2, 2007 | 07:34 PM
Picturepro's Avatar
Here in So. Cal lots of cops use Lazer at the front plate, I feel it may not work as well, mounted high
Ie. 1000 feet lazer at front plate only has 15 inch circle beam, Closer to the detector.
I even email the guy who test all the detectors. He said Highter for Ka better distance
lower for lazer, because it has a small beam up to 2000 feet, most lazer ticket are 700-900 feet
Old Apr 2, 2007 | 07:38 PM
Mugen_is_best's Avatar
it seems like no one has read the owner's manual on mounting and positioning; It says to mount it as high as possible.
Old Apr 2, 2007 | 09:41 PM
chuhsi's Avatar
I've read "mount high"...I've read "mount low."
V1 recommends that their detectors are mounted as high as possible..so that's what I do.
I'm hard wired to the left of the rear view mirror.
Old Apr 2, 2007 | 10:24 PM
Project22a's Avatar
I was under the assumption that by the time you've been alerted of a laser, they would've already gotten a reading.
If that's the case than Ka is way more important.
Old Apr 2, 2007 | 11:20 PM
chuhsi's Avatar
I don't think I've ever been shot with laser. I get false laser alerts frequently, though.
Ka is by far the most important band for me.
K and X are useless
