RADIO INSTALL
Old Sep 28, 2008 | 05:02 AM
dickeyduncan's Avatar
Default RADIO INSTALL
Looking at all of those installs is really mind boogling. My question, does anyone have a step by step instruction guide for removing the OEM radio and installing an aftermarket such as the Sony MEX BT5100 or like device on a 2007 S2000?
I am about to install one with the IPOD and HD adapters. Need some help in removing the old.
Thanks
Old Sep 28, 2008 | 06:34 AM
darkknight1999's Avatar
Ready...
Set...
Remove shifter handle. Unscrews... righty tighty lefty loosy
Pull up on the center console tray. Just pull... its just clips
Open radio door, grab radio door close to the hinges... and pull... I know its tight... PULL like a man...
Once the bottom releases wiggle the top section near the vents and the door will pop off.
You'll see 4 screws to remove the deck. Take them out.
Unplug deck...
Put on the shelf...
Done
Old Sep 28, 2008 | 10:19 AM
philbert's Avatar
here's the unofficial AP2 install guide:
https://www.s2ki.com/forums/index.ph...ic=404767&st=0
Old Sep 28, 2008 | 10:25 AM
G's Avatar
G
You can do it without removing the shift knob and center console on AP1's not sure if AP2's are different.
Old Sep 28, 2008 | 10:47 AM
The AP2's are different.
Old Nov 4, 2008 | 01:16 PM
Thanks all for that info. I got the radio installed, had to cut a small slot in the door however.
Now I haven't been able to get the remote controls working using the aftermarket wiring control device.
I installed the MEX BT 5100 by SOny.
Is there another control device which will work?
Thanks again
Old Nov 4, 2008 | 02:38 PM
Cubs2k's Avatar
Thanks again
Old Nov 4, 2008 | 03:49 PM
SgtB's Avatar
Old Nov 4, 2008 | 04:27 PM
Neutered Sputniks's Avatar
IBTL?
Gatsbee13
18
Jan 24, 2009 08:25 PM
SLstone s2k kid
Jan 19, 2007 01:00 PM
puffycloud9
Apr 3, 2005 01:54 PM
bucsdork99
Mar 26, 2005 09:09 PM
SilverKnight
Jul 17, 2004 11:10 AM
