radio nd speaker question?
Old Jun 7, 2013 | 05:54 AM
s2kking's Avatar
Default radio nd speaker question?
I'm buying a radio nd some speakers but I'm not sure if I need a install kit for the radio nd I don't know what size speakers to get for the doors...
Old Jun 7, 2013 | 07:39 AM
BLAQ&GREYs2k's Avatar
No radio kit needed for the headunit you will buy. It will come with two right angle brackets. You screw on side to the HU and one side to the factory screw holes. For the speakers you will need 6 1/2" mids and 1" tweeters.
Here's what I bought and they sound amazing!
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
You will need a spacer for most aftermarket door speakers for the 6 1/2" mid to clear the inside of the door. About 3/4" spacer is sufficient and easy to make your self or to buy.
Old Jun 7, 2013 | 09:47 AM
s2kking's Avatar
Ook kool thnx
Old Jun 10, 2013 | 06:22 PM
oth's Avatar
oth
A couple of things -
if you want your dash controls to work with an aftermarket headunit, you need to buy a headunit capable
of some sort of remote control, either IR or hardwired, and a dash control interface (DCI) to translate
the dash commands to the headunit. There are others, but the most popular is the Modifry DCI.
In addition, you'll want an adapter harness such as Metra 70-1721. Be aware that many of these don't
have the S2000-specific dash wires, so if you intend to use a DCI, buy Modifry's adapter harness which
certainly does. You may also want speaker harness adapters.
Finally, most headunits don't come with the above-mentioned brackets, but you can reuse the ones that
are bolted to the factory headunit.
Old Jun 11, 2013 | 05:23 AM
takeshi's Avatar
certainly does.
...and if you want a really install then get Modifry's PnP harness (only available for a couple of brands of head units IIRC).
roel03
Jul 23, 2018 05:26 PM
Chance S2K
Jan 1, 2014 12:36 PM
Rob88
Oct 18, 2009 04:26 AM
LordStanley
Nov 24, 2008 05:35 AM
Venomous S
Sep 13, 2004 07:14 PM
