Radio Powers off briefly
Old Aug 12, 2011 | 05:43 PM
alwayshonda's Avatar
Default Radio Powers off briefly
Ok, I'm new to the site so forgive me if this is in the wrong place. I have a 2004 s2k, and every so often, the factory radio will shut off completely for just a second or two, then power up again all on its own. I have no idea what is causing this. Everything else works properly, and right now it is the factory head unit (though I will be upgrading it this weekend with an Alpine CDA-117). I don't know if an aftermarket head unit will solve the problem, or if there is some other issue with the car's electrical. Any help is appreciated.
Old Aug 12, 2011 | 09:11 PM
S2K.Danny's Avatar
Everytime I've seen this it was due to a loose/faulty/corroded ground connection for the deck. When you install the new Alpine unit, just ground it to a new point, not the stock radio harness - the problem should not persist.
my 2 cents
Old Aug 12, 2011 | 09:17 PM
lltysonll's Avatar
I have this same issue, although it doesn't bother me much. I have Alpine IDA-X305S, modifry dash control, & polk components. Sometimes cuts off when charging Iphone or some times when turning on headlights.
Old Aug 13, 2011 | 09:53 AM
Boost-Me's Avatar
It is very unlikely that the ground is the problem. Factory radios have iso mount brackets that are connected to the chassis and there is a ground in the harness and the antenna is also a ground (not a good one but a ground none the less). Sounds like the radio itself is going out, so putting the 117 in should solve this problem. If not check the yellow and red wired for a loss in power when the radio shuts down. This will let you know which circuit is causing the problem.
Old Aug 18, 2011 | 06:10 PM
Thanks for the help, I'm almost finished with the Alpine install.
S2Koupe
Aug 8, 2006 08:33 PM
wickerbill
May 1, 2006 07:06 PM
dut
May 21, 2004 01:32 PM
Sleepy
Nov 5, 2003 10:20 AM
revhi
Jan 31, 2003 06:01 AM
