Radio turns on with use of cig lighter with ignition off
Old Jan 15, 2012 | 02:17 PM
Mr White's Avatar
Default Radio turns on with use of cig lighter with ignition off
So today while using an air compressor to fill my tires I noticed my radio came on when I powered my air compressor from my auxiliary port(cig lighter) I could change the song, turn up/lower the volume from the side controls. As soon I unplugged the compressor the music stopped...I think my car is possessed.
Old Jan 15, 2012 | 06:06 PM
Vi3tbo1209's Avatar
lmao! thats wierd
Old Jan 24, 2012 | 03:33 PM
roosty's Avatar
thats awesome!
Old Jan 24, 2012 | 03:37 PM
S2k007's Avatar
For some reason they use the same fuse. My radio stopped working a while back, fixed the radio fuse, still didn't work, changed the accessory fuse and it works. I sometimes blow the accessory fuse by plugging something into the outlet and there goes my radio. I just don't use it the outlet anymore.
Old Jan 25, 2012 | 11:20 AM
TPhong's Avatar
That's really odd, but unless your cig lighter has been rewired, it shouldn't work unless they key is turned at least to the ACC position. If the key is turned to either ACC or IGN/RUN the radio should cut on. I would check the wiring to the cig lighter plug first. Does it do it if anything is plugged in (phone charger, GPS, etc) or just the air compressor?
austind
May 8, 2012 06:22 PM
PokS2k
Jan 29, 2011 02:11 PM
rugsr
Apr 4, 2007 05:22 AM
gbuka
Apr 27, 2005 10:45 AM
Yellow Belly
Aug 15, 2002 08:50 AM
