RCA & Speaker Wire
Was reading some old posts, such as Speaker Wire
and still have a few questions on RCA & speaker wire.
For running a front components and a rear sub from one 4 channel amp- two channels bridged for the sub- does the RCA configuartion make any diffence?
What I mean is two sets of RCAs (4 wire) vs. a pair of RCA's + a subwoofer RCA (3 wires). I noticed KnuKonceptz has a new sub RCA http://www.knukonceptz.com/productDetail.c...odID=KRY1.4M-KP
It seems the sub would only need a mono RCA...
Any other brand of RCAs besides Knu that I should consider?
For the component speaker wire, who makes 4-wire twisted pairs?
Im confused when you say a subwoofer RCA that is mono. . you should have 2 pair of RCA's running to the back, one pair for the front channels and 1 pair for the sub.
Some suggested brands would be : Monster, Streetwires, Stinger or even consider the amp manufacturer, they may have a high grade kit for you.
That is one of my questions- can a mono subwoofer amp be connected with only one RCA?
I had planned on using a pair of RCAs until I saw this cable http://www.knukonceptz.com/productDetail.c...odID=KRY1.4M-KP
Any advantage?
Any advantage?
what amp are you using? That may help clear it up.
I cannot recall a mono sub amplifier, it would be a "stereo" input (2 rca ends) and then you create a single channel on the speaker output.
The item you are looking at is for a home theatre application and not for a car.
