rear harness
Old Apr 1, 2002 | 06:23 PM
Cyberorth's Avatar
What does the speaker end of the 2002 rear speaker harness from Lucid look like?
Is there a fitting that matches Honda's generic speaker harness(what comes on OEM speaker wires inside the door)?
Old Apr 1, 2002 | 07:04 PM
lucid's Avatar
The part on the left is from the harness - right speaker panel (premium wire lead 12" is attached to speaker terminals and insulated).
Every panel set sold has this feature. The terminal pins (soldered on both plugs) are to be inserted into the male (from harness) plug when it is in the cavity. You can't fish the wire down the console with the plug attached.
No wire ties, soldering, crimping or taping is required. Installation is quicker and easier than ever. If a speaker is faulty it can easily be unplugged and replaced OR if a better model comes out in the future you're able to upgrade in minutes.
Old Apr 1, 2002 | 07:51 PM
Cyberorth's Avatar
I only ordered the harness. Is this picture the speaker end of what I ordered or is there a line all the way to the back of the speaker?
Thanx in advance
Old Apr 1, 2002 | 08:19 PM
lucid's Avatar
What you are looking at is the rear speaker connection - part of the rear speaker kit. The Radio harness is just that, it taps the rear lines of the unused speaker leads (4 wires) and you attach your speaker wires to 4 loose wires (green/purple) and run them back.
In a "kit" the wire bundles are soldered and double insulated to the harness with pin terminals. The value of the OEM kits is that everything is done for you so a complete installation can take 40-50 minutes by a novice.
Old Apr 1, 2002 | 08:49 PM
Cyberorth's Avatar
So I can run my speaker lines all the way to the back of the stereo and wait for the harness?
Old Apr 2, 2002 | 03:36 AM
TampaS2k's Avatar
You can but if you solder the rear speaker lines onto the harness you will want to do it outside of the car.
Old Apr 2, 2002 | 04:45 PM
Cyberorth's Avatar
I knew that.
Thank you Lucid and TampaS2k.
ignition25
Feb 10, 2007 08:53 AM
jbim
Dec 5, 2003 06:57 AM
purdue2k2
Aug 30, 2002 09:25 PM
millenniumRX2
Dec 11, 2001 10:51 AM
xviper
Oct 5, 2001 08:23 AM
