reloating the bettry for FI
Old Apr 28, 2007 | 09:11 PM
s2guru's Avatar
Default reloating the bettry for FI
i need to relocate my battery to the truck for my turbo setup or what othe ropcion i have?
what the best way to run the new wires to the back?
Thanks
Old Apr 29, 2007 | 03:22 PM
s2guru's Avatar
anyone?
Old Apr 30, 2007 | 08:09 AM
CarbonS2000's Avatar
If you dont have a sound system you can run the spoon or the t1r mini battery. Does it have to be removed 100%?
Old May 4, 2007 | 08:12 PM
s2guru's Avatar
Originally Posted by CarbonS2000,Apr 30 2007, 10:09 AM
If you don't have a sound system you can run the spoon or the t1r mini battery. Does it have to be removed 100%?
yes if have to be remove to the turck, i have a audio system so i will be using the the stock one in the truck....
my main question, how to get the 4g wire from the engine bay to inside the cab, from the passage side.. drill the firewall?
Thank you
Old May 4, 2007 | 10:24 PM
NFRs2000NYC's Avatar
No, look at the firewall from the engine bay when you remove the battery. You will see a grommet with lots of wires running into the car. Peel back the black tape, lube the wire, and feed it through. Its a bit annoying your first time, but itll slip in eventually.
Old May 6, 2007 | 07:34 AM
Reborn56's Avatar
^^ pervert lol
GreenmanS2000
Car Talk - Non S2000
20
May 21, 2016 02:18 AM
richardmai92
Sep 7, 2015 06:55 AM
CIVICTOS2000
Aug 17, 2005 01:04 PM
TIMELESS
Oct 8, 2003 10:22 PM
Gotta_Go_Faster
Apr 16, 2003 05:36 PM
