Remote Central Locking Failure
Old May 9, 2014 | 01:14 PM
N1ck88's Avatar
Default Remote Central Locking Failure
Hi all,
I am new to the forum, but have been keeping an eye on them for sometime. Unfortunately, I've had a few issues with my S2000 recently, so figured you were the guys to ask.
So, I have searched the forums for my issue, but generally found incomplete solutions or situations that differ from mine, so here goes...
My remote central locking has stopped working. It has failed over time in this order:
1. Car would not unlock one door (passenger) via the remote
2. Car would not unlock either door via the remote
3. Car would not unlock or lock either door via remote
At this point, I researched the issue and found about the locking motors. I stripped and cleaned the motors as per the thread I found. The door would then lock, but not unlock via the remote.
I replaced the locking units in the doors with Rock Auto replacement ones - doors still lock but not unlock via remote.
Boot opens with the key fob. Doors lock/unlock fine with key.
When pressing the keyfob to lock the door, I can hear a 'click' from the unit under the steering column. When unlocking, I hear no noise.
I have therefore come to the conclusion the central locking module under the steering column has failed. Is this a replaceable part or is it coded to the key/ecu/car?
Does this sound a feasible assumption?
Old May 13, 2014 | 02:14 PM
Belkin623's Avatar
I am experiencing the same problem. The remote will turn on and off the car alarm, but will not lock or unlock my doors. If I find a fix and it works, I'll post it!
Old May 15, 2014 | 11:51 PM
N1ck88's Avatar
Thanks!
Can anyone tell me if the contril unit under the steering column is interchangeable? Or is it coded to key/car?
Part number is 38380-s2a-g02
Contl unit. Dr&t/g lock & keyless
Old May 16, 2014 | 03:49 AM
oth's Avatar
oth
The Helms manual has fairly extensive instructions for testing the keyless control unit, but has
no specific instructions for replacement. My guess is that after replacing the module you'll need
to program your transmitters into it, which there are instructions for.
Old May 16, 2014 | 03:58 AM
N1ck88's Avatar
I don't have a Helms manual, nor am I familiar with them (UK). Could you suggest where to purchase/download etc?
Old May 16, 2014 | 05:14 AM
oth's Avatar
oth
The US version of the manual is available from the publisher Helm Inc.. Looks like eBay is
a source for both paper and CD versions.
In addition, there was a PDF going around the internet a few years ago, you may be able
to find a download. This is also a possibility though I haven't tried it.
Old May 16, 2014 | 05:46 AM
N1ck88's Avatar
Thanks oth. Looks like it can be changed and reprogrammed - good news!
rolso72
Sep 11, 2016 02:02 PM
bruce0293
May 24, 2013 10:10 AM
bruce0293
May 24, 2013 04:37 AM
PENROD
Tampa
16
Apr 16, 2009 12:24 PM
milomika
May 17, 2008 03:03 AM
