Remote Trunk Release 'Dead'
Old Jan 16, 2011 | 06:19 PM
JDR159's Avatar
Default Remote Trunk Release 'Dead'
I can't open my trunk with the key FOB or the button in the glove box. I've checked/replaced both the 30 amp fuse (# 54 under the hood), and the 15 amp (#26) in the fuse block inside the car. I've put a meter on the leads at the latch and I am NOT GETTING 12 volts ('0' volt reading) when I activate either the FOB or the switch. I am getting 12 volts to the trunk light, which shares the same wiring harness....
Any thoughts on what else to check?
thanks.
Old Jan 16, 2011 | 09:18 PM
jaundice's Avatar
Bad trunk release solenoid. Unfortunately, its in the trunk. Open the trunk with the key and figure out if its got any juice.
Old Jan 18, 2011 | 10:34 AM
JDR159's Avatar
As I mentioned in my original post, I do NOT have 12v at the solenoid now. Yes, the fuses are good. Really hoping it's not a break in the wiring harness. Will be tough to find and repair.
fangtastic
Feb 23, 2014 01:02 AM
4PLAY2K
22
Jun 7, 2011 02:46 AM
niahuynh
Jul 8, 2008 12:31 PM
Mountain Man
May 4, 2005 07:34 AM
