Removed Speakers, Kept Wiring Connected..Question.
Old Nov 28, 2009 | 06:26 PM
zeroptzero's Avatar
Default Removed Speakers, Kept Wiring Connected..Question.
Hi, I am a total noob when it comes to audio stuff. I had a set of rear hoop speakers , I removed them and cut the wiring and taped up the ends as best as I could reach, so the wiring for the rear speakers is still attached to the HU running through the console from the rear. I now put the fader to full front to direct all of the sound to the front speakers. My question is if I have to remove the wiring that is connected to the HU that is not being used from the rears ?. If it is better to remove it I will, but if it makes no difference then I'll leave it as it stands. Thanks for any replies on this.
Old Nov 29, 2009 | 07:28 AM
AMS MIKE's Avatar
why did you remove the hoop speakers? you could have just directed the sound to 100% front. There was no need to remove the speakers and cut the wires....unless you removed the whole hoop itself to put a cage or something.
Since its too late now, better make sure you electrical taped them seperately and good so cannot short your electrical system.
Old Nov 29, 2009 | 08:44 AM
zeroptzero's Avatar
I removed them for a couple of reasons. I didn't care for the sound to come from behind my head, it sounded good but I didn't like the effect. The speakers were in the hoops when I bought the car. The speakers occupied the entire hoop and extended outwards toward the seat a fraction of an inch. Removing them allowed a bit more light to shine through the hoops and improved the appearance, I also didn't have to worry about the seats touching the speaker screens as I push the seat back as far as possible. The previous owner had two mdf panels sandwhiched between the front and rear hoop, creating a box like structure within the hoop which the speaker sat within and the speaker screen extended outwards on the front.
I did tape the speaker wires pretty good, but I might look at pulling it out completely just to be safe from short issues in the future. Thanks for the info on this.
Old Nov 29, 2009 | 01:20 PM
AMS MIKE's Avatar
ahhh and i was thinking OEM hoop speakers. No wonder you wanted to remove them.
Old Nov 29, 2009 | 03:23 PM
zeroptzero's Avatar
Hi, yeah no they are a custom made speaker setup.
Old Nov 29, 2009 | 05:22 PM
oth's Avatar
oth
as long as the cut ends are well insulated - electrical tape is fine, and if you
snipped the wires so no wire is sticking out of the wire's plastic insulation,
there's very little risk even if the tape comes off - there is no reason to
pull the wires leading to the rear.
Old Nov 29, 2009 | 08:22 PM
zeroptzero's Avatar
thanks for the reply on this, I believe I snipped them pretty clean and good bit of electrical tape on them for good measure. So if there is not much harm in leaving them the way they are then it makes sense to leave them in place, they are burried out of sight. Thanks for the help on this.
amped_imports
Sep 24, 2012 02:25 AM
VTEC Racer
Dec 27, 2008 08:48 PM
BioBanker
Oct 27, 2004 07:36 PM
SaNgO5
Apr 18, 2002 07:49 PM
Team Hybrid
Mar 21, 2002 08:15 PM
