Removing Pin from Electrical Connector
Old May 22, 2008 | 02:58 PM
yyyiiikes's Avatar
Default Removing Pin from Electrical Connector
I am needing to remove a pin/wire from an electrical connector rather than cutting the wire itself. Is there a special tool for this?
Thanks!
Old May 22, 2008 | 03:22 PM
aslude's Avatar
No special tool needed. If you look at the connector there are slots where you can use a small flathead screwdriver to de-pin it.
Take a look at this site, the author briefly shows how to de-pin wires for its connector.
Hope that helps.
Old May 22, 2008 | 06:10 PM
yyyiiikes's Avatar
That's a great link... I will book mark it for future reference.
But, the connector I am working with (the convertible top connector) does not have side slot access.
Old May 22, 2008 | 06:56 PM
aslude's Avatar
In that case, you can use a small screwdriver or a pick to go from the front or the back of the plug. Hard to explain without a picture. If there are multiple openings from the front, for example, usually you can insert something small into the hole to loosen the pin. What you want to do is disconnect the clip of the pin where it sits.
Old May 23, 2008 | 07:33 AM
SgtB's Avatar
There is a special tool you can use. Some radio shacks stock it for about $5.
Old May 23, 2008 | 11:03 AM
DER MotorSports's Avatar
We like these for general stuff
but may I also suggest a set of QUALITY Picks are invaluable
jelanier
Mar 7, 2014 05:37 AM
tx2K
May 10, 2013 11:25 AM
iluvs2ks
Sep 9, 2011 03:27 PM
User 32625
Jun 6, 2006 03:26 PM
evilbeatfarmer
Apr 18, 2005 08:29 AM
