Coil Pack Connetor Pins
Old Mar 6, 2014 | 02:09 PM
jelanier's Avatar
Default Coil Pack Connetor Pins
I have a broken coil pack connector on my S2000. I have the new pins and a new connector. How do I remove the old pins? Do they come out from the wire side or connect side?
Do I need a pin extraction tool?
Thanks
Jim
Old Mar 6, 2014 | 02:21 PM
freq's Avatar
Thanks
Jim
jewelers screwdriver(s)
Old Mar 7, 2014 | 05:37 AM
c130turboprop's Avatar
first u must pull out the blue piece inside the connector, then a pick to push up on the pin release inside the connector. the wire and connector will pull out from the wire side. dont use jewelers screwdrivers, use a nice sharp pick to "grab" the release and pull up on it slightly. using something dull like screwdriver u run the risk of mesing up the release and making it hard to "grab" the release. if the actual coilpack is broke, u will have to buy a new coil pack as its a one piece unit.
i recently redid my own engine harness, posted in this thread i made are some tools that may help you
https://www.s2ki.com/s2000/topic/106...-find-pinouts/
geared
Aug 25, 2012 05:49 PM
yyyiiikes
May 23, 2008 11:03 AM
User 32625
Jun 6, 2006 03:26 PM
Phormula_01
Feb 19, 2002 08:14 AM
Fiend
May 23, 2001 06:38 PM
