removing stock headunit?
Old Dec 4, 2003 | 06:23 PM
Rusler Firbrand's Avatar
Default removing stock headunit?
anyone know what screws i have to remove and wheres the location? hopefully somone with a helms diagram.
Old Dec 4, 2003 | 06:29 PM
mcomer's Avatar
First you have to remove the cover with the door. Open the door and hold it open at about a 45 degree angle, then pull sharply outward to free the cover assembly at the bottom. Or, open the door fully and then gently pry the top of the cover (the seam is right above the little vents - the vents are part of the cover assembly) outward with a putty knife or a screwdriver wrapped in electrical tape. Either way, once you get the cover/door off there are two screws on either side of the radio that you remove. The screws are the top and bottom ones - the middle ones hold the HU to the brackets, which will slide out with the radio.
Lucid has a guide for how this is done:
http://www.lucidautomotive.com/guides/radio/
Old Dec 5, 2003 | 01:43 PM
wow, i just took it off right now, thanks man your a life saver.
Old Dec 6, 2003 | 04:36 AM
mcomer's Avatar
No problem. Glad to help.
Matt
Old Dec 6, 2003 | 09:39 PM
mazdaspeed00's Avatar
yea it took me a while to figure out how to remove the head unit.
Old May 16, 2005 | 12:33 PM
rioja's Avatar
old thread i know, but i've been scouring the web trying to figure out how to remove the damn HU! thanks
harleyboy
Feb 11, 2007 12:26 PM
toosoonjunior
Nov 27, 2004 04:41 AM
redlineracing
Dec 9, 2003 09:12 AM
wagnerb
Jan 29, 2002 11:52 AM
mcochran
Dec 31, 2001 05:03 AM
