Running Stereo Power
Old Feb 25, 2006 | 10:00 AM
Haulin' S's Avatar
Default Running Stereo Power
Trying to run a 4 guage power cable from the battery to the trunk to connect to my capacitor and then to my amps. Any suggestions on the best way to run through the firewall? Prefer not to be drilling holes, but if that's the easiest way, so be it.
I want to run along the passenger side of the car beneath the door plate. Soooo if anyone knows a good way to get from the bat to the passenger side thru the firewall, LEMME KNOW!
Thanks!!!
Chris
Old Feb 25, 2006 | 11:01 AM
Triig's Avatar
Check out this post. There might be more under the FAQ's at the top of the Electronics forum.
https://www.s2ki.com/forums/index.php?showtopic=248785
Old Feb 25, 2006 | 11:05 AM
Haulin' S's Avatar
I saw that one, but can't make out which grommet he went thru.
Old Feb 25, 2006 | 12:38 PM
Triig's Avatar
According to that write up, he went through the one right under the brake master cylinder. Which is the same one I went through when I did mine. I just used a razor blade to make room for it to slide through.
Old Feb 25, 2006 | 01:19 PM
thraak's Avatar
I used that hole for my 4 ga. Streetwires cable. I did not have to cut it. It was hard to get it through until I put a little Armor All on it.
Thraak
Old Mar 1, 2006 | 12:10 AM
Haulin' S's Avatar
Thraak
I got it guys! Thanks for the help. Woulda told ya sooner, but something was wrong with the site and I couldn't post!
Old Mar 1, 2006 | 05:04 AM
Pulse's Avatar
I used the one behind the battery. Made for a very easy run.
Just pull the batt. out and look behind it. the wire will drop down right behind the firewall on the pass. side.
Old Mar 1, 2006 | 07:06 AM
jwa4378's Avatar
There should be a grommet RIGHT near the battery, on the passenger side. If you can wait til this weekend, I can snap a photo of it for you. This was how I ran my wires.
John
Old Mar 1, 2006 | 11:38 AM
S2000GT's Avatar
this is the easiest and most direct route to get your power cable down the passenger side
Old Mar 5, 2006 | 03:59 PM
Haulin' S's Avatar
Again, guys, thanks, I ran it across the engine compartment and throught the firewall near the master cylinder. Then down the door jam on the driver's side. That way all the wiring that will most likely cause interferance is on that side, and my RCAs can be run down the passenger side with my video cable for my rear camera.
