Running wires through fire wall? How?
Old Sep 7, 2011 | 05:36 PM
elvir's Avatar
Default Running wires through fire wall? How?
Im installing some extra lighting and i need some pointers. Is there a preferred access through the firewall that can be accessed inside of the vehicle to run wiring to the center council for a switch? Also is there a preferred way to tap a power source with a wire already attached with a fuse into the battery?
Thanks Guys
Old Sep 8, 2011 | 06:48 AM
oth's Avatar
oth
Here's a thread about using the accessory connectors in the under-dash fusebox.
There are others, found through a forum search for "fusebox accessory".
Here's a thread on routing wires through the firewall. I did a search on "firewall grommet"
to find it and others.
Old Sep 8, 2011 | 10:01 AM
elvir's Avatar
awesome, thanks for your help, i tried searching but i guess i just wasn't searching for the right link.
Old Sep 8, 2011 | 10:21 AM
oth's Avatar
oth
it helps if you've seen the posts before, and have a good idea what keywords they likely include
Old Sep 9, 2011 | 08:43 AM
RobHimself's Avatar
I recently ran 4 awg cable quite easily through the grommet right next to the battery on the passenger side. Just have something to poke through and some windex and you'll be set.
Old Sep 12, 2011 | 07:09 AM
takeshi's Avatar
...and sometimes a site-restricted Google search will yield better results than the built-in forum search.
Fujin
Feb 20, 2019 07:55 AM
xtremesq
Mar 15, 2008 06:59 PM
Blurter
May 23, 2005 01:38 AM
Notion
Sep 13, 2002 05:23 PM
Kibro
Sep 16, 2001 11:47 AM
