Heated Seat Wiring to Accessory Fuse
Old Feb 19, 2019 | 06:19 PM
Fujin's Avatar
Default Heated Seat Wiring to Accessory Fuse
Hey guys,
I've been searching but can't seem to find the answer so I'm hoping someone here has a link or has figured this out. I am currently running wiring for Heated seats. Using Watercraft heaters. They use 12V power each and have a 10amp fuse inline with an accessory holder. I know often people wire these to the Acc. 10 Amp 12 V lighter but I often charge my phone while I drive and that load would be too much.
Has anyone successfully wired these instead to the 3 accessory sockets in the driver side under dash fuse location? Can I join the positive leads to a single 20amp fuse and run negatives to the battery? Any advice would be great! My goal is to wire this as "Factory" As possible.
Old Feb 20, 2019 | 05:31 AM
oth's Avatar
oth
The fusebox option connectors are definitely the way to go, specifically "C" which is only powered when
the engine is running.
These are connected to a 40A fuse in the under-hood fusebox, so it should be able to supply all the
current you need. Don't forget to disconnect the battery (-) connection when working!
You can connect both seats to the same fusebox terminal, but each wire needs to remain separately fused
as the fuse is sized to protect that one wire.
Finally, there is a factory ground point near the fusebox which you can use to ground the seat heaters.
Alternatively, if the ground wire (-) is separate from the (+) wire, you can ground it to the chassis closer
to the seat.
E - on with the headlights
D - on all the time
C - on with the ignition
Old Feb 20, 2019 | 05:56 AM
Fujin's Avatar
Q
to the seat.
D - on all the time
awesome. When connecting both leads to the fuse location should I splice together into a single female connector? Alternatively I’d be fine upgrading wire harnesses to a heavier gauge wire if needed.
Old Feb 20, 2019 | 07:55 AM
oth's Avatar
oth
yes, you can twist the two wires together and crimp them into a single connector
JawKnee
Feb 6, 2012 09:02 AM
9kI4
Aug 26, 2007 12:46 PM
Thistler
Aug 19, 2005 09:45 AM
Blurter
May 23, 2005 01:38 AM
Scanman
May 12, 2004 10:03 PM
