Head unit Alpine CDA-9887R with KCE865B for dash controls. Yes, I know it could do with a clean up there
Imprint is in use and makes a very positive difference, although it's negated by having both roof and windows down. The windows make more difference to sound quality than the roof position though (unsurprisingly).
Speakers are old-ish Alpine SPX-177R 6.5" components.
Amps are hidden above the fuel tank, an Alto Mobile ADP-304 4x75, bi-amped to the SPX-177Rs and a JL Audio 250/1 for the Subwoofer.
Here's the rack
and here it is hidden away
Finally, a Darkside V1 passenger (although it's on my driver's) side box with Alpine SWS-1043 sub
I still have room for groceries, golf clubs and all sorts.
Forgot about the Ebay special iPod Classic 40Gb in the glove compartment.
^^^ very tidy, i have my amp in the same place I think its a great hiding spot! & the sub is in a good spot, plenty of room for shopping I like but the head unit area could do with a clean
Quick question about the imprint.
I have a ida-x100 with the imprint manually tuned (sort of). I haven't tried the computer and mic based tuning yet, but i have all the pieces for it.
Does the automatic tuning ever boost frequencies?
I have a pretty high-powered sub and I'm afraid that if the imprint module boosts something on the low-end, when i turn it up it will clip the amp.
Do you think this is possible?
How exactly does the imprint do it's thing? just timing and eq?
Also make sure you have access to an external battery charger as doing a full Imprint run is likely to leave you with a flat battery.
You still have access to the subwoofer level control, even with Imprint (or Multi-EQ as it's known) engaged. However, a common complaint with the system is that the bass disappears.
I think this is essentially because a lot of people have their subs set up to produce mid-bass, rather than sub-bass, and Imprint correctly sets the crossovers much lower than most had them before.
My humble 10" sub can happily rattle the boot (or trunk) lid with the Imprint engaged.
I am, however, more of a quality over quantity sound person, so I prefer a more subtle approach to subwoofers.
Most people complain about a loss of bass because they're not used to what bass is supposed to sound like. Bass is not supposed to overpower the rest of the music, however much anyone else believes such to be the case
Alright thanks, that actually helps a lot.
I'm still a little worried about overboosting some frequencies, especially on the sub side.
I don't think I'll have a problem hearing the sub at all then. considering that I'm more about the low end of a sub and have mine crossed at about 63hz as it is. This sub plays loud all the way down to 10hz, so as long as it doesn't crank up the boost, i should be alright.
Can you make manual adjustments to the multieq after it does it automatically, or is it all or nothing?
[QUOTE=DBXFX,Jun 17 2009, 06:50 AM] Alright thanks, that actually helps a lot.
