S2000/F20c Alternator wiring
Old Dec 8, 2011 | 06:18 AM
meewisse's Avatar
Default S2000/F20c Alternator wiring
Hello everybody,
We (my father and I) are building a VM77 kitcar with a F20c/S2000 engine. We want to instal an aftermarket ECU so we have a custom wiring. At this moment we are preparing the car for the first start. Now we want to wire the alternator but some (most) of the cables we can't connect because we dont have the standard ECU.
The connectors of the alternator can be seen in the picture below:
My first thoughts are:
connecting the black (+) wire to the +side of the battery
connecting the black/yellow wire to the +12v contact with the ignition switch.
and that's it.
Is this right? Or will the alternator not work?
Thanks already!!!
Old Dec 8, 2011 | 06:45 AM
T-Smac's Avatar
it will not work. The ecu controls the alernator output based on the signal it recieves from the alternator. This is done to reduce load and increase fuel economy.
Old Dec 20, 2011 | 05:12 AM
meewisse's Avatar
Right now the engine is running well and I assume that the alternator works well. The voltage of the accu is around 14,5 volt.
We have connected the BLK/YEL wire and the WHT/BLU wire with light bulb.
Old Dec 21, 2011 | 07:58 PM
T-Smac's Avatar
That's fantastic. Make sure to watch for an overcharge condition. The system may not be regulating voltage as it's designed to.
Old Dec 22, 2011 | 07:31 AM
meewisse's Avatar
Thanks T-SMAC, We will watch the voltage when driving.
S2KRail
May 9, 2012 09:49 PM
Luke_sedz
Nov 15, 2011 03:21 PM
lotus7racer
Aug 18, 2008 04:33 PM
modifry
Aug 20, 2002 12:07 PM
modifry
Aug 19, 2002 05:42 PM
