S2k wont start up. Dead silent
Old Jan 9, 2016 | 07:48 PM
Patruss90's Avatar
Default S2k wont start up. Dead silent
Hey guys. I'm new to the thread and recently had a situation with my s2k. It won't start up at all.
Turn the key
Hit the clutch, gears in neutral
No noise, no start.
Battery is fully charged
I'm able to start the car up with a screwdriver touching the studs on the solenoid to the starter...could it be just a bad solenoid overall?
Old Jan 11, 2016 | 05:57 AM
windhund116's Avatar
Sounds like connections to solenoid or bad unit, itself. First, check the large gauge wires going from battery to starter (and solenoid). Good clean & tight contact.
Good luck!
Old Jan 11, 2016 | 06:32 AM
AE_Racer's Avatar
probably the plastic piece on the clutch pedal that hits the clutch switch. they get brittle and break, typically found on your floormat in pieces.
here is a diy to bypass it which im not recommending you do or dont do, but it has pictures/diagrams to show what im talking about https://www.s2ki.com/s2000/topic/619...switch-bypass/
Mine broke years ago, I stuck a small bolt and nut in its place and havent had an issue.
If the plastic piece is present and doing its job then you will need to look elsewhere. good luck
Zerolagoon
Aug 2, 2017 07:02 AM
Patruss90
Jan 11, 2016 07:36 PM
Soviet
Jul 12, 2015 06:02 PM
Jag528
Feb 24, 2013 11:20 PM
BionicPimp
Aug 27, 2012 11:40 AM
