Satalite radio
Old Feb 14, 2010 | 08:19 AM
kylemonster85's Avatar
Default Satalite radio
I was just wondering where people have mounted their satalite radio antenas. does it have to be on the outside of the car i dont really want to gave it out there if i dont have to. Any suggestions
Old Feb 15, 2010 | 03:30 PM
toyrunner's Avatar
You can allways put it on the Dash somewhere .
Old Feb 16, 2010 | 05:53 AM
TexasGPWS2k's Avatar
^^ this will work, if your using the factory antenna, then your gonna have to put it on the trunk. as long as it has a clear view of the sky, it will work just fine.
Old Feb 16, 2010 | 07:47 AM
Will it get just as good reseption on the dash or will it be to staticky
Old Feb 17, 2010 | 11:45 AM
WhrDLMI's Avatar
I have mine mounted behind the windscreen on a small square of velcro (soft side to the antenna). Works find with the soft top up or down. When I put the hard top on, I relocate it to one of the metal tabs that stick off off the window frame. Works like a champ!
I've been told that the signal will go through glass, plastic, and fabric just fine. It is metal that is an issue.
Old Feb 17, 2010 | 12:17 PM
JayKnight's Avatar
I have mine mounted on the top of the windshield.
The one I have is magnetic and sticks to the metal
frame the windshield is in. Also it is about the size
of a Silver Dollar and about 1/2 inch tall.
I have the wire tucked under the dash and up the A
pillar and across the top rubber trim, and then I just
laid my antenna on top of the window frame, and I
have about 1/2 - 3/4 of an inch of wire showing.
The top does not pinch on the wire at all when closed.
Old Feb 17, 2010 | 01:58 PM
dr.darkness's Avatar
Behind the windscreen also.
Old Feb 17, 2010 | 04:02 PM
you will have no issue with having the antenna by a window like the front windscreen. ive personally ridden in at least 3 cars with the antenna in a window inside the car. there is no issue with noise what so ever.
Cayne82
Mar 14, 2016 06:10 PM
Bloody Hatch
Nov 19, 2012 04:18 AM
NFRS2K83
Jun 30, 2009 08:07 AM
dr.darkness
Oct 14, 2008 09:23 PM
whythot
Feb 22, 2006 09:04 AM
