Scan Gauge II OBD2 reader
Old Jul 16, 2006 | 03:54 AM
mad-dog-one's Avatar
Default Scan Gauge II OBD2 reader
Anybody have experience with the Scan Gauge II OBD2 reader. It is supposed to sample info from the OBD2 circuit and calculate MPG, GPH, velocity remaining fuel, etc. Any feedback regarding experience with this device will be appreciated.
Thank you
Old Jul 16, 2006 | 09:33 AM
NFRs2000NYC's Avatar
All these things do is estimate. They look at the figures your car puts out, and calculate MPG, etc. The ones I used, did work. I dont know if they were accurate, but they do take realtime readings.
Old Jul 17, 2006 | 10:38 AM
modifry's Avatar
Honorary Member
These devices can poll the ECM for data and then make calculations based on that data. Speed, rpm, manifold pressure, air temp, and a bunch of other readings are available. But I've never seen fuel rate or fuel tank readings on my when using the PC-based OBDII unit I have so I doubt they are available.
Which means you won't be getting MPG or other fuel estimates, at least not on an S2000. Also bear in mind the OBD connection isn't very fast and if you're pulling 3 or 4 pieces of data you'll only get updates every 2 seconds or so. That's OK for long-term measurements but won't necessarily tell you accurate maximum speed or rpm as they could occur between captures.
RussianHammer
Feb 19, 2015 05:06 PM
99SH
Aug 20, 2013 02:30 PM
Chris S2K
Jun 19, 2010 03:21 PM
BigTed
May 23, 2003 03:33 AM
