Sidemarker and turning signal problem. Help please
Old Sep 13, 2005 | 07:45 PM
sifuhomer's Avatar
Default Sidemarker and turning signal problem. Help please
I had my oem sidemarkers stolen a while back and I recently purchased new connectors, sockets, bulbs and jdm sidemarkers for replacement. However, I now have a hyperblinking problem on the left sidemarker and the left rear turn signal. Also, the front left turn signal isnt working. Everything on the right side is working perfectly normal. Can anyone diagnose this problem and offer advice on how to fix it? Any help would be appreciated. Thanks!!!
Old Sep 13, 2005 | 08:34 PM
S2000GT's Avatar
The fact that you were down a bulb on the left side (sidemarker) probably caused you to blow your left turn signal. Now you have replaced the sidemarker, the hyperblinking is because you still have an issue on that side - probably the blown turn signal.
If it is as simple as that - all you need to do is replace your turn signal bulb - lets hope its nothing more serious.
Old Sep 13, 2005 | 08:46 PM
xviper's Avatar
Exactly. That "hyperblinking" is telling you a bulb is burnt out. That's how modern day cars let you know this sort of thing.
In the "old" days, when you activated a turn signal and a bulb is burnt out, the indicator on the dash would just stay on solid and not blink at all. Times change.
Old Sep 14, 2005 | 02:54 AM
sifuhomer's Avatar
Thanks for the help...I will work on it later today. Hopefully it is as simple as a blown bulb.
ftpsk8
Apr 12, 2011 06:51 PM
motoinfantry
Aug 17, 2009 01:02 PM
Randman
Aug 12, 2009 08:43 AM
VAs2000Berlina
Oct 8, 2005 03:45 PM
bobatimez
Nov 4, 2001 09:37 AM
