Snapped a wire in door panel
Old Jul 29, 2010 | 09:27 PM
ayau's Avatar
Default Snapped a wire in door panel
while attempting to snake a speaker cable through the rubber grommet (driver's side), i accidentally snapped a wire. it's a pink/blue stripped wire that goes to the electronic window/side mirror controller device. does anyone have any idea what this wire does? i've tested the power windows/side mirrors and they seem to all work fine.
also, how would i remove the metal door panel if i were to try to solder the wire back together?
Old Jul 30, 2010 | 04:16 AM
NFRs2000NYC's Avatar
Be more specific, where is this wire located?
To make it simple, if you can find both ends, fix it.
Old Jul 30, 2010 | 07:05 AM
Will's Avatar
I don't think you can remove the interior metal panel... It's part of the door. If you don't want to solder, or aren't able to, try a quick splice connector...
Old Jul 30, 2010 | 07:08 AM
ayau's Avatar
looks like i might be able to putll the cords out of the grommet to do the soldering. it's a pain though with all that tape wrapped around the wires.
Old Jul 30, 2010 | 07:17 AM
Seattle2k's Avatar
unwrapping tape is a pain?
Old Jul 30, 2010 | 08:10 AM
ayau's Avatar
combined with trying to pry out the rubber grommet out, yes.
Old Aug 1, 2010 | 04:50 PM
oth's Avatar
oth
I'd just snake in a new section of wire, and splice the two broken ends
to the two ends of the new wire.
Old Aug 1, 2010 | 05:16 PM
ayau's Avatar
i was actually able to pull the set of wires out of the door grommet and solder the wire back. thanks!
5STARSTUNNA
Feb 27, 2012 04:55 PM
futique
May 30, 2010 08:25 PM
Moddiction
30
Nov 2, 2009 05:39 PM
sweetsleeper
Aug 25, 2005 05:25 PM
matrix
Mar 31, 2003 06:43 PM
