Soundgate Auxiliary Input Converter
So, I bought this assuming it would be a seamless integration in to my 07 s2k. It's really been anything but. I installed it correctly and all the plugs are where they're supposed to be. When I installed it the first time, it worked. I buttoned everything up and then turned it back on. It didn't work. Took everything apart again and realized it's a very tight fit in to the stock radio cd changer. I made sure the plug was seated as far as it could go and snug in the socket. I took it for a drive, and it worked just fine. I get in the car a few hours later and it doesn't work again.
I have a few theories why...
1. When I felt the Box that has the RCAs and plug going to the radio are... it was extremely hot to the touch. This indicates to me that power is going through it. There's no reason it would be hot to the touch after the car's been off for hours and wasn't driven far before hand.
Electronics and heat don't get along and this is my strongest guess...
2. I got a defective unit and someone's already had a problem with it and I just didn't know or check beforehand.
Help! This has my head hurting
vertigyn
Mar 19, 2017 06:22 PM
