Speaker adapter for focal 165k2
Old Jul 12, 2003 | 04:21 AM
ankuse's Avatar
Default Speaker adapter for focal 165k2
I was just wondering, if I were to make a speaker adapter out of mdf, what thickness do i need for these speakers, 1/2 inch or 3/4 inch?
thanks alot
ankur
Old Jul 12, 2003 | 04:40 AM
PAS2KNut's Avatar
I made mine with 3/4".
Old Jul 12, 2003 | 06:35 AM
InsaneInNC's Avatar
PAS2KNut,
Just a note: Your Focals are the Utopia version; Ankuse was asking about the Poly-Kevlar version. I'm not sure if the two lines have the same mounting depth; I don't have the spec sheet handy to compare.
Old Jul 12, 2003 | 08:10 AM
PAS2KNut's Avatar
I just checked the mounting depth and both have a 78mm depth.
Old Jul 12, 2003 | 08:57 AM
ankuse's Avatar
thanks alot for the info, one other quick question, was there any problems putting the door panel back on, anything pushing out of the door panel.
and also where did you wind up mounting the tweeter.
again thanks alot
ankur
Old Jul 12, 2003 | 11:01 AM
PAS2KNut's Avatar
again thanks alot
ankur
I had no problem with the door panel. I didn't have to modify anything on the door panel. I have an 02 so I put the tweeter in the factory location. Here is a picture of were PJK3 put his Focal tweeter.
If you do a search under tweeter, tweeter location, tweeter position you will get all kinds of ideas.
Old Jul 12, 2003 | 12:18 PM
PJK3's Avatar
i really like the tweeter there...
it's far enough forward that unless you're specifically tryin, legs don't block it and w/ the tweeter set at the -2db on the crossover, it's still crisp and clear at that location. the phasing of the mids to highs stays good, the wind doesn't effect one more than the other, and unless you really look for it - you can't see it, so the car still appears stock.
flexctacy
Feb 11, 2010 03:15 AM
DBXFX
May 19, 2008 07:59 PM
Ajjra
Feb 12, 2004 12:51 PM
Cigar Man
Mar 21, 2003 05:04 AM
THRILLR
Feb 20, 2003 06:33 AM
