Trying to replace my door speakers
Old Feb 9, 2010 | 08:24 AM
flexctacy's Avatar
Default Trying to replace my door speakers
ok, ive got no clue on how to get the door speakers out so i can replace them. im sure i have to take the door panel off but how to do i go about doin that without breaking the panel? obviously its not like my integra where the speaker casing would just pop off and it was simple to replace them. if anyone has any pointers on how not to break something, let me kno. thanks.
Old Feb 9, 2010 | 08:29 AM
ou818's Avatar
There are clips holding the panel to the door You have to pry them loose (I use a screwdriver with a cloth wrapped around it.)
Also: https://www.s2ki.com/forums/index.php?showforum=26
Old Feb 9, 2010 | 08:32 AM
flexctacy's Avatar
sweet. thanks a lot boss.
Old Feb 9, 2010 | 08:37 AM
CKit's Avatar
Don't forget the screws in the inner door handle and the screw in the inner door latch.
I use a trim tool wrapped in a towel to pop off the panel.
CKit's Avatar
And keep in mind that some speakers aren't shallow enough to fit.
Old Feb 9, 2010 | 08:56 AM
MikeyCB's Avatar
Taking the doors off is a very quick procedure once you've done it or seen it done. You'll have your second door off in 90 seconds.
In addition to the comment about shallow speaker needs, you may want to consider making/buying a spacer/ring to pull the new speakers out a little so you can go with something a little deeper. Just make sure they aren't too deep or your window will hit the magnets when you roll it down.
Old Feb 9, 2010 | 08:59 AM
Not Sure's Avatar
Here's a how-to with some good pics:
https://www.s2ki.com/forums/index.php?showtopic=483031
Old Feb 9, 2010 | 09:24 AM
The Gasman's Avatar
Yeah, that's a very good point. If your speakers go in too deep, the electric windows will hit the magnets on the way down.
Old Feb 11, 2010 | 03:15 AM
phonedrn8's Avatar
3 min to take mine off unscrew and unclip
DBXFX
May 19, 2008 07:59 PM
Ajjra
Feb 12, 2004 12:51 PM
Cigar Man
Mar 21, 2003 05:04 AM
BlueIrishS2k
Aug 27, 2002 11:09 AM
Steve2K
Jul 6, 2001 11:35 AM
