Speaker issues
Old Jan 4, 2011 | 07:48 AM
Dappa's Avatar
Default Speaker issues
I fitted my new Rockfords and they seem to be playing up.
They cut out time to time and come back to life with a whack of the door card.
As far as I am aware all connections are tight.
Any clues what it could be ?
Old Jan 4, 2011 | 07:51 AM
suzuka-blue-s2k's Avatar
The only thing I could think of is a loose connection somewhere. I would double check just to be sure.
Old Jan 4, 2011 | 08:49 AM
TPhong's Avatar
if all your connections are tight, make sure the speaker connections and/or speaker wire isn't grounding out on the chassis or door anywhere.
Old Jan 5, 2011 | 08:19 AM
Baron2099's Avatar
Loose connection, amp power surge, or loose amp connection to the battery under the hood
Old Jan 8, 2011 | 08:08 AM
Round 3's Avatar
Speaker terminals might be hitting the door skin or window might be hitting it on the way down. do you have speaker spacers?
Old Jan 10, 2011 | 11:59 PM
eumylove's Avatar
Maybe its a defective speaker. The voice coil might be torn and when it bumps or rattels it can disonnect or have a loose end. If all the connections are correct you should deffinatly check the speakers it self
MaxAP1
Aug 23, 2017 12:25 AM
Penforhire
Aug 24, 2008 06:01 PM
sleeze
Sep 13, 2006 05:54 AM
s2k330
Nov 20, 2005 02:14 PM
J Nick
Mar 23, 2004 06:03 PM
