Speaker Make / Models
Old Apr 1, 2008 | 11:29 PM
garethrees's Avatar
Default Speaker Make / Models
Hi All,
Been doing a search and not really found a definitive guide to speaker model # installs (apologies to anyone if I missed it.)
With that in mind I thought I'd start a thread where people could add their specific speakers make and model number so newer members could help decide which ones to upgrade to.. (like me)
I've found one or two topics but most people seam to leave out the details... so here we go:
Make / Model / Location / Review or Comment (optional)
Poke / EX2540 / Rear / na
Poke / 602 / Front / na
Kenwood / KFC-1077 Rear / na
Infinity / 452i 4.5 / Rear / na
Infinity / 652i 6.5" / Front / na
Alpine / SPX 137 / Rear / na
Please note:
Not all 4" speakers will drop in due to size restrictions. 4" speaker with
a magnet diameter of 3 1/16 or less will fit without cutting metal
Please don't just add the make 'Lucid / na / Front / na' for example as this makes it difficult for new members to look up the actual model used.
As I find speakers in threads I will add them, but if anyone else wants to help great!
Old Apr 2, 2008 | 06:37 AM
daktruckie99's Avatar
Polk / DB 651 / Front / Drop in replacement with no cutting.
Old Apr 2, 2008 | 06:42 AM
Neutered Sputniks's Avatar
Diamond Audio Hex S600s Will not fit OEM speaker basket at all, but fits inside the door without a spacer ring. Minor dremel work required to fit the tweeters.
Old Apr 2, 2008 | 07:06 AM
Habitforming's Avatar
JL Audio / ZR650-CSi / Front /
Remove oem baskets, cut new mounts from 1/2" MDF or ply. Outside profile same as OEM basket, inside circle is diameter of speaker basket. Be careful of concentricity to hole in the door, only about 1/4" total clearance between basket and door hole.
Tweets - use OEM mounting plate and JL's flush mount cups. Trim cups to fit between the mounting 'posts' for OEM tweets. This is for MY04; other years may vary.
Old Aug 21, 2011 | 06:31 AM
garethrees's Avatar
Finally fitted:-
DLS / RS6 Slimline (DLS-RS6) / Front / No cutting, just new mounting plate, good base
DLS / C5A (DLS-C5A) / Rear / S-Pods Direct Fit.
The fronts needed 6 1/2 brackets which I got off ebay:-
http://www.ebay.co.uk/itm/6-Speaker-...#ht_1328wt_905
itsmeek
Sep 18, 2006 06:36 AM
nazaracing
Aug 25, 2005 06:42 AM
Paper Lawyer
May 1, 2004 03:38 PM
QuickS
Sep 10, 2003 04:35 AM
stockae92
Jan 8, 2003 05:19 PM
