Speaker upgrade question
Old Oct 17, 2007 | 06:41 PM
Silver Surfer's Avatar
ok well i did a little bit of research according to what you guys have said, and this is what i came up with......
Pioneer TS-D701P
is there anything technically wrong with those speakers as far as my application?
60watts rms
91dB sensitivity
25Hz - 32kHz
64.5mm depth
If this is a poor choice could you give the reason why and an example of a speaker that would be better and why?
thanks for all the help so far, hopefully i can come up with something decent while staying stock
Old Oct 17, 2007 | 10:29 PM
stopmenot2002's Avatar
I've got Infinity Kappa 63.7I not yet installed I am waiting for the dynamat door kit to arrived then I will let you guys know.
Old Oct 17, 2007 | 11:29 PM
tekstar's Avatar
will you be running these with an amp?
Old Oct 18, 2007 | 04:20 AM
that's not an answer, in fact we already concluded that you shouldn't use the power hungry kappa without an amp.......
Old Oct 20, 2007 | 04:20 AM
Pioneer HU 880PRS has internal amp so no extra Amp. one AMp for the Subwoofer though.
Edited from other forum Ive found. I guess it would be okay.
While we
Old Oct 20, 2007 | 05:29 AM
Will's Avatar
Kappa speakers are 2 ohm. Head units are not 2 ohm stable; they need speakers that are 4 ohm--or else you'll fry your head unit. And 99% of head units have an internal amp, btw. You still need an external amp for those Kappas.
Old Oct 21, 2007 | 07:27 AM
Neutered Sputniks's Avatar
Just my humble recommendation...
Don't look for low power speakers, look for high efficiency speakers. It's nice to have the option of adding an amplifier at some time in the future without having to replace the door speakers as well.
I have Diamond Audio Hex series in the doors, powered by my Eclipse head unit. The sound is amazing. One of these days (maybe today even), I'll get my amp wired in and they'll sound even better.
The key, though, is high sensitivity. The more sensitive a speaker, the better the sound reproduction and the less power it will need to perform well.
Old Oct 21, 2007 | 05:03 PM
chickdr's Avatar
Another plug for the Polk dB6500/6501. I just upgraded the door speakers with my stock system and they sound great. Nice bass and very efficient. You should notice even more difference as I understand the stock speakers have improved over time. If yours are factory 2002 MY speakers they are getting old and likely need replacement anyway.
Old Mar 31, 2008 | 08:07 AM
colorado's Avatar
Hi, did you use the Polk-DB6500, how did they fit? I was told they are too tall for the door panel. I have a 2001. Please let me know.
Thanks.
Wendell
you can pm me at:
wstephens16@yahoo.com
Old Mar 31, 2008 | 02:11 PM
kpxtweeks's Avatar
to be honest if your looking for a little improvement over the stock setup it will be ok.... if you want to be going 85+ with the top down and want to be able to understand what is playing.... then go add an amp. running speakers off the deck is not the right way to do it, just get it amped amd you will be glad you did.
Whoabitchin
Mar 19, 2011 11:16 PM
Mr Dave
Apr 16, 2009 01:21 AM
sodaking663rd
Sep 24, 2006 08:38 AM
VTEC Racer
Apr 10, 2003 02:59 AM
hc68
Jul 14, 2002 02:50 PM
