speaker wire...
Old Jan 1, 2009 | 12:19 PM
s2k aok's Avatar
Thumbs up speaker wire...
alright i am installing a wideband and have been splicing and soldering my display, control unit, test switch, and led. i needed to add a little extra length for the grounds and the 12v power and i didn't want to have to drive to an auto store or walmart to get a little spool of wire.
i do have a lot of excess stereo speaker wire left over from adding stereo components. i figured wire is wire, the speakers i figure are getting more juice than the wideband would require, so i said what the hell and used it. i'm thinking nobody does this 'cause of the substantial wire cost between the two but i'm not an electronics expert.
so, should i finalize the install and hook up the power to the wideband and run it or should i stop and get the traditionally accepted wire?
Old Jan 1, 2009 | 12:47 PM
Neutered Sputniks's Avatar
My concern would be the insulation around the wire itself. If you put the speaker wire on the inside of the car, I wouldn't worry. If the speaker wire is on the outside (engine compartment/underside of car) I'd be concerned about it's resilience to weather/wear & tear.
Old Jan 1, 2009 | 04:35 PM
devilchrist's Avatar
not so much weather as inside the doors they are pretty beat up.. but.. heat is not something these insulations will be able to resist.
Old Jan 1, 2009 | 04:40 PM
s2k aok's Avatar
alright, thanks for the information, i'll finish the install tomorrow (just attaching the grounds and the power source)...
siadam
Jul 3, 2010 08:59 AM
Ludeboye1
Mar 23, 2009 01:26 PM
mikdys
May 7, 2008 05:01 AM
2004S2000
May 18, 2007 12:03 PM
pikkashoe
Nov 8, 2004 08:37 PM
