Speedometer problem
Old Aug 31, 2011 | 10:51 PM
S2000_FUN's Avatar
Default Speedometer problem
Hello,
While i had the car in my garage waiting for a spare part to fix a mechanical problem i decided to remove the cluster bezel to replace a blown light bulb behind it. I decided also to remove the speedometer cluster. Then i put everything back and when i received the spare part i went to the garage to fix the mechanical problem. Yesterday i took the car from the garage and went for a ride. I left the car to eat something and when i took it again i noticed that the speedometer was reading 0Km as speed even if the car was moving. Everything else was working fine even the rpm, all sensors and also the total Km reading and the trip reading were working fine. Just the speed meter was continiously at zero. I do not believe is the VSS sensor cause everything else is working fine
I do not have a yellow jacket installed in my car and i could not see if i got an EPS light cause i have an AEM ECU but the power steering is working fine. I do have a modifry temperature calibrator but that was installed ages ago.
Any ideas why it is reading zero?
Chris
Raines48
Feb 14, 2017 07:43 PM
Joeh
Jul 26, 2010 12:45 AM
Lttakas
Aug 30, 2009 12:55 AM
dimi
Sep 25, 2007 12:50 AM
msm_s2k
Jun 29, 2006 09:20 AM
