EPS quit
Well I park my car, get out, noticed my crooked parking and went back inside to readjust. Turn the car on and the steering wheel is very hard to move and EPS light is on. Hmmm, so I park the car and get to class. 6 hours later it works again.
Anything that I should be worried about? Thanks guys.
It does throw codes, which can be used for diagnosis.
Main thing that usually causes this is high RPMs (over 2000) without the car moving, or low RPMS (under 500) with the car moving. In both cases the EPS suspects a bad speed sensor and shuts itself off.
Originally Posted by IcebergS2000,Sep 24 2007, 10:30 PM
Can these codes be checked with a OBD scan tool? Or is there more to it?
The "blink" codes for the EPS DTC's can be checked by jumping PIN's on the OBDII DLC then looked up without an expensive tool though.
Same thing shown here:
http://www.k-series.com/tech_detail.php?Tech_ID=CEL
Only the EPS light blinks instead of the CEL.
EDIT: I guess the other way would be to use a laptop running the HDS software hooked up to the car via HIM. (Honda Interface Module) I think this is the cheapest of the 3 HDS methods supported by Honda.
